No Heat Need Help Tried Everything
Old 11-04-2008, 08:07 PM
Default RE: No Heat Need Help Tried Everything
I would replace the hoses just due to age and the potential for problems when removed. It is more of a precaution than anything else. Heater hose is cheap enough.
Old 11-11-2008, 07:14 PM
Always Something's Avatar
Always Something is an unknown quantity at this point
Wow, get this. We tested the flow from the hot water supply. Nothing coming out from the engine. We will pull the pipe tomorrow to see if it is clogged. But the latest theory is that someone replaced the manifold gasket at some point and did not remove the correct tabs. AutoZone says they sell the gasket for 1988-1993. Depending on the year you remove different tabs. Please tell me this ain't so!
Old 11-11-2008, 07:27 PM
That would suck, but could explain why you have no heat.
trippymg
02-17-2012 08:10 PM
rocker665
10-23-2011 01:55 PM
storm17angel
03-14-2011 05:37 PM
ekh08
03-23-2009 02:19 PM
Mr2turbox
01-31-2008 10:28 PM
Quick Reply: No Heat Need Help Tried Everything
