No Power...
Old Aug 9, 2007 | 09:38 PM
Shizer's Avatar
Shizer is an unknown quantity at this point
Default No Power...
When I first bought my truck about 6 months back you could barely hit the gas and the front would raise up and throw you back in your seat. Now its getting to the point to were Its taking alot longer to shift to 2 gear and its weak. I have changed the plugg wires, spark pluggs, Air filter,Fuel Filter Unit and all, and new tires. All this was done before the power started going down hill. I ended up cutting the Cat Converter off today thinking that would help seeing it was busted but really the only change is its idleing better. The temp on the motor is also starting to raise alot Its at 210 in less than 2 mins of driving. I'm stumped , I'm taking into the shop after I junk the converter and have them look it over. Any ideas on how to get my power back?
Old Aug 9, 2007 | 10:14 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
Default RE: No Power...
When was the last coolant flush, sounds like this might help cool the engine if it was replaced, also you may need to replace the thermostat. When you replaced the plugs and wires which brand and type did you use (ie. AC Delco Platinums) and what did you gap your plugs too? These are just a couple things that might help.
Old Aug 10, 2007 | 01:36 AM
Shizer's Avatar
AC pluggs, and what do you mean by gaps? I just tighted the pluggs untell they stoped.
Old Aug 10, 2007 | 09:02 AM
I mean the gap at the end of the plug you put in the engine between the elctrode and the insulator
If I remember right, when I got mine they were already gapped properly, but you should double check them before you put them in. They should be gapped to .60 inches. An inproper gap would cause bad spark resulting in loss of power and possibly fuel economy.
Old Aug 10, 2007 | 01:42 PM
Shizer's Avatar
Duh, I'm not thinking today or something. Anyways checked em, Auto Zone said they should be at about 35 and their at 45. Also just got a new Turbo Chery Bomb Muffs. About to TRY and fix my front cv axle and take it out for a ride. If it keeps not wanting to shift to 2nd I ain't going muddin this weekend.
Old Aug 14, 2007 | 09:28 PM
Hanr3's Avatar
Mud in the radiator will cause cooling issues as well. Take a garden hose to the radiaotr and clean the fins really well.
Verify your plug gap. It changed over hte years and improperly gapped plugs will cause all sorts of performance and cooling issues. Mzkd xure your plugs are gapped properly for your engine.
flipzat
Dec 2, 2009 04:05 PM
fresno99
Jul 31, 2009 08:12 PM
1991whiteoutblazer
Jan 8, 2009 08:17 PM
nate2003456
Jan 18, 2007 01:10 AM
freeman
Aug 23, 2005 10:55 PM
