o2 sensor
Old Nov 29, 2006 | 02:09 AM
babyboy's Avatar
babyboy is an unknown quantity at this point
Default o2 sensor
does anyone know were the o2 sensor is for a 1994 s-10 blazer 4x4 4.3 vortec
Old Nov 29, 2006 | 02:11 AM
Default RE: o2 sensor
In the exhaust directly after the primary tubes of the y-pipe come together directly before the cat.
Old Nov 29, 2006 | 02:17 AM
slammins15's Avatar
slammins15 is an unknown quantity at this point
x
Old Nov 29, 2006 | 02:35 AM
rooster's Avatar
rooster is an unknown quantity at this point
i could be mistaken but i dont believe they introduced the three o2 sensors in the blazer untill 95, although they were introduced to the pickups in 94, and the bravada in 96. but if im wrong then the other two sensors would be located in the left exhuast manifold and just past the cat., and of course the first is in the right manifold. are u pulling any codes, 13/44/45 are left bank and codes 55/61are right bank. 5 digit-po131-134/135/137/138/140/141
Old Nov 29, 2006 | 09:50 AM
I haven't checked my references, but the '94 is a CPI motor. The PCM requires 1 O2 sensor for the fuel injection system. Being a '94, it is also an OBD1 system which I do not believe requires a catalyst monitoring sensor. I think in '95, a pre & post cat sensor was added along with the mongrel OBD1.5 PCM specifications. In '96, the OBD2 was in full use and sometime early to mid year the switch was made to the SCFI motor. Form '96-'97, 4 O2 sensors were used (2 upstream, a pre-cat sensor, and a post cat sensor). In '98, the pre-cat sensor was deleted and the 2 upstream sensor traces were averaged to get a pre-cat measurement.
That is all from memory so I wouldn't take it to the bank, but I think that is correct. I don't have my references at work so I can not look it up... But please, correct me if I'm wrong!
Old Nov 29, 2006 | 10:49 AM
rooster's Avatar
according to my references u nailed it on thr head bro. you nerd, jk hahahaha!!
joey
Aug 27, 2012 06:33 PM
GM hater
Jan 9, 2010 02:32 PM
theeviltwinn
Oct 23, 2009 06:37 AM
daniel010
Feb 2, 2009 06:50 AM
Spartan66
Jul 11, 2008 02:34 PM
