OBD code 12 (california)
Old Dec 10, 2013 | 12:43 PM
linsgm's Avatar
linsgm is on a distinguished road
Default OBD code 12 (california)
FINALLY, got truck to have it smogged (did not pass-i knew it) failed ignition timing 5 atdc, and failed OBD systems check. so far reset timing ( per advice from previous post ). oh yeah, checked codes fist before doing timing and got 12, 13, 42 (california ) then corrected timeing, and now just have 12 can u explain? oh 92 s10 blazer 4.3 vortec,
Old Dec 10, 2013 | 02:42 PM
DesertStorm's Avatar
Code 12 is just to show it is in diagnostic mode and all codes are clear
here is a list of all codes for GM OBD1
DTC - 12 No distributor reference pulse (diagnostic test active)
DTC - 13 Oxygen sensor circuit open or no activity
DTC - 13 Left bank O2 sensor circuit open or no activity
DTC - 14 Engine coolant temp sensor error (high temp indicated)
DTC - 15 Engine coolant temp sensor error (low temp indicated)
DTC - 16 System voltage too low
DTC - 17 Camshaft position sensor error
DTC - 21 Throttle Position sensor error (signal high)
DTC - 22 Throttle position sensor error (signal low)
DTC - 23 Intake air temp sensor error (low temp indicated)
DTC - 24 Vehicle speed sensor error (open circuit or no activity)
DTC - 25 Intake air temp sensor error (high temp indicated)
DTC - 26 Quad Driver Module (QDM A) error
DTC - 28 Auto transmission range pressure switch error
DTC - 31 Wastegate solenoid circuit error
DTC - 31 Gear Position Switch (PRNDL) error
DTC - 32 EGR system failure
DTC - 33 MAP sensor circuit error (signal high indicating low vacuum)
DTC - 34 MAP sensor circuit error (signal low indicating high vacuum)
DTC - 35 IAC problem or idle error
DTC - 36 MAF sensor error
DTC - 36 24x Crankshaft position sensor circuit error
DTC - 36 4T60-E Shifting Error
DTC - 37 TCC brake switch circuit error
DTC - 38 TCC brake switch circuit error
DTC - 39 Clutch switch circuit error
DTC - 39 TCC error
DTC - 41 Ignition control error
DTC - 41 MEM-CAL error
DTC - 41 C³I Cam Sensor Signal error
DTC - 42 Ignition bypass circuit error
DTC - 43 Knock sensor error
DTC - 44 Oxygen sensor error (lean condition indicated)
DTC - 44 Left bank O2 sensor error (lean condition indicated)
DTC - 45 Oxygen sensor error (rich condition indicated)
DTC - 45 Left bank O2 sensor error (rich condition indicated)
DTC - 46 Pass-Key II (VATS) system error - circuit out of freq range
DTC - 47 UART (serial data) circuit error
DTC - 51 PROM error
DTC - 51 Incorrect MEM-CAL
DTC - 52 Fuel cal-pak incorrect or missing
DTC - 53 System voltage too high
DTC - 53 Digital EGR Valve solenoid 1 error
DTC - 54 Fuel pump circuit low voltage
DTC - 54 Digital EGR Valve solenoid 2 error
DTC - 55 ECM error
DTC - 55 Digital EGR Valve solenoid 3 error
DTC - 56 Quad Driver Module (QDM B) error
DTC - 57 Boost Control error
DTC - 58 Trans fluid temp sensor circuit error (low voltage)
DTC - 58 VATS system error
DTC - 59 Trans fluid temp sensor circuit error (high voltage)
DTC - 61 A/C system performance
DTC - 63 Right bank O2 sensor circuit error
DTC - 63 MAP sensor circuit signal voltage high (low vacuum indicated)
DTC - 64 Right bank O2 sensor lean exhaust indicated
DTC - 64 MAP sensor circuit signal voltage low (high vacuum indicated)
DTC - 65 Right bank O2 sensor rich exhaust indicated
DTC - 66 A/C pressure sensor circuit error (low pressure indicated)
DTC - 67 A/C pressure sensor circuit error
DTC - 68 A/C clutch relay circuit error (shorted to ground)
DTC - 69 A/C clutch relay circuit error (open circuit indicated)
DTC - 69 A/C high pressure switch error
DTC - 70 A/C pressure sensor circuit error (high pressure indicated)
DTC - 71 A/C evaporator temp sensor circuit error (low temp indicated)
DTC - 72 VSS signal circuit error
DTC - 73 A/C evaporator temp sensor circuit error (high temp indicated)
DTC - 75 Digital EGR solenoid #1 circuit error
DTC - 76 Digital EGR solenoid #2 circuit error
DTC - 77 Digital EGR solenoid #3 circuit error
DTC - 79 Transmission fluid overtemp
DTC - 80 Transmission component slipping
DTC - 82 3x Crankshaft position sensor circuit error
DTC - 85 PROM error
DTC - 86 A/D error
DTC - 87 EEPROM error (flash memory error)
DTC - 90 TCC error
DTC - 93 Transmission pressure control solenoid circuit error
DTC - 96 Transmission system voltage low
DTC - 98 Invalid PCM program
DTC - 99 Invalid PCM program
Old Dec 11, 2013 | 04:02 AM
linsgm's Avatar
Default oh my gosh
u mean it might pass smog??????
Old Dec 12, 2013 | 01:27 PM
abig84's Avatar
do they actually plug it into the computer? out here anyhing pre 95 they just stick the thing on the tailpipe and smog it that way.
Old Dec 13, 2013 | 12:40 PM
linsgm's Avatar
machine
Old Feb 27, 2014 | 09:13 AM
Dave884x4's Avatar
Dave884x4 is on a distinguished road
In southeast Texas, If the diagnostics port doesn't work, and the CEL isn't on they run a tailpipe sniff test and pass it that way.
Old Feb 27, 2014 | 01:25 PM
abig84's Avatar
that would be nice, but you figure everyone with a code on will just clear the light and pull the fuse so they can get smogged. im lucky where i live they dont have emissions for my old junks
rowe
22
Dec 10, 2018 10:45 AM
MeidleinA
27
Jun 9, 2009 06:40 PM
ffbacker
Apr 16, 2008 12:14 PM
rastaskater
Mar 12, 2008 06:22 PM
Blazermania97
Mar 8, 2008 04:18 PM
