oil cooler line
Old Dec 5, 2006 | 11:32 PM
FImports's Avatar
FImports is an unknown quantity at this point
Default oil cooler line
whats the easiest way to remove the oil cooler line on a 92 s-10 blazer..........thanks
Old Dec 6, 2006 | 01:33 AM
rooster's Avatar
rooster is an unknown quantity at this point
Default RE: oil cooler line
well if its the one that goes from the oil filter to the eng then u will need a very long 2 ft extension and a floor jack and a piece of wood. the bolt heads i believe are 9/16, along with a 1/2 ratchet you will need to feed the socket and extension through the steering linkage area towards the bolt. oh but before that u might need to jack up the eng slightly to get past the motor mount. so put the wood under the oil pan and lift it with the jack.so after u feed the extension through then carefully remove the old lines, and install is the reverse of removal except be very carefull when feeding and turning the new lines into position. u dont want to crimp or disturb the fittings on the lines. otherwise the cooler line is pretty straight foward, two bolts off two bolts on.
Old Dec 6, 2006 | 04:56 PM
FImports's Avatar
thanks for your help.should i drain the oil first
Old Dec 6, 2006 | 08:28 PM
rooster's Avatar
no thank u, but yes drain the oil and do a complete change with filter. its cheap enough
rodman
Nov 21, 2009 08:08 PM
ChevyFamily
Jul 10, 2009 06:41 PM
Newbeme
Feb 8, 2008 10:42 PM
dublin1
Sep 8, 2007 08:12 PM
Jetfixer
Jul 11, 2006 05:02 AM
