Oil Cooler Lines
Just wondering if I would have to remove engine mounts to get to that oil line that runs to the engine block.
I posted in another forum 2 days ago, but still no responces, and since nobody has responded, I just made a new post.
Both of my lines are leaking and needing some insight to what I need to do to get to these (what to do, and not to do)
Thanks!
(shes still running!)
Thanks!
Listen I have just finished fixing my oil line leaks. I have replaced them before with them starting to leak again in less than a year. I have a solution for you and you need not pull any lines or replace. Send me a private message with your your contact info and I will let you know what to do. It is to involved to sit here and type it out and must be done correctly.
I'm having trouble identifying the ones i need. I can't seem to find the exact one. Is there a sure-fire way of identifying exactly what part I need? They keep asking if I have 4wd or heavy-duty cooling. no on the first and no clue on latter. The idea that i dont have original engine is becoming more prevalent every time i do something to this truck.Thanks
fslobodecki@yahoo.com
Apr 15, 2011 03:29 PM
subarugt06
Mar 6, 2011 11:21 AM
