Oil Cooler Lines
Old Feb 18, 2012 | 04:16 PM
choover82's Avatar
choover82 is on a distinguished road
Default Oil Cooler Lines
Just wondering if I would have to remove engine mounts to get to that oil line that runs to the engine block.
I posted in another forum 2 days ago, but still no responces, and since nobody has responded, I just made a new post.
Both of my lines are leaking and needing some insight to what I need to do to get to these (what to do, and not to do)
Thanks!
(shes still running!)
Old Feb 19, 2012 | 09:53 PM
richphotos's Avatar
You may need to unbolt a mount to get enough clearance to get the line out,
Old Feb 20, 2012 | 01:02 AM
choover82's Avatar
Thanks for replying. Need to know for when it gets warmer out.
Old Feb 27, 2012 | 10:17 AM
harley745's Avatar
harley745 is an unknown quantity at this point
Listen I have just finished fixing my oil line leaks. I have replaced them before with them starting to leak again in less than a year. I have a solution for you and you need not pull any lines or replace. Send me a private message with your your contact info and I will let you know what to do. It is to involved to sit here and type it out and must be done correctly.
Old Mar 6, 2012 | 08:14 AM
AllegedGangsta's Avatar
AllegedGangsta is on a distinguished road
Can anyone tell me where to buy the Oil Cooler Lines from?
@Harley745 - What does "fixing" them involve?
Old Mar 6, 2012 | 08:23 AM
xgiovannix12's Avatar
you can get them at your local auto parts or try online rockauto or ebay
if ya go with rockauto there is a discount code in my signature
rockauto is usually the cheapest
Old Mar 6, 2012 | 08:51 AM
I'm having trouble identifying the ones i need. I can't seem to find the exact one. Is there a sure-fire way of identifying exactly what part I need? They keep asking if I have 4wd or heavy-duty cooling. no on the first and no clue on latter. The idea that i dont have original engine is becoming more prevalent every time i do something to this truck.Thanks
Old Mar 6, 2012 | 09:17 AM
bigcountry58's Avatar
bigcountry58 is on a distinguished road
Harley, I would appreciate if you spent the time typing out your solution... As I am having the same issues.
Old Mar 6, 2012 | 09:50 AM
well depends witch one is leaking the ones going to the radiator? or the the ones going under the motor
fslobodecki@yahoo.com
Apr 15, 2011 03:29 PM
subarugt06
Mar 6, 2011 11:21 AM
Jetfixer
Jul 11, 2006 05:02 AM
eng69
Jan 31, 2006 04:55 PM
zero psi
Oct 28, 2005 04:45 PM
