Oil leak, HELP!
Old Oct 27, 2013 | 08:53 PM
bensaintonge's Avatar
bensaintonge is on a distinguished road
Default Oil leak, HELP!
I have a 92 4.3 TBI 4x4 with an oil leak somewhere. There is residue on the oil and transmission pans but the most oil is coming from the oil filter adapter up a little higher. I 95% sure the leak is coming from there. What do I need to fix it?
This? https://www.rockauto.com/catalog/x,c...parttype,10422
Old Oct 27, 2013 | 09:08 PM
Yup, or Felpro gasket set ES 70016, about $5 available at most auto parts stores.
Old Oct 27, 2013 | 09:44 PM
chris015's Avatar
pop the 2 bolts loose,1 bolt for the hoses (go in from the front of the truck using lots of extensions) pull the adapter down and you will have a huge oring,and up against the block will be a paper gasket. IF your lucky it'll be stuck to the adapter and not the block. enjoy chipping away the gasket lol. make sure the areas clean for the new one.
tip : put one layer of electrical tape under the head of both bolts (not for the lines though) and stick em in the adapter. then stick the gasket over the bolts. The tape will hold the bolts from falling out. Whalla! i had a hella time with keeping the bolts in,and gasket lined up. only enough room for 1 hand...at least mine. im a fatty.
Old Nov 6, 2013 | 12:52 PM
Bernard's Avatar
Bernard is on a distinguished road
Mine starting to leack a little ....94.
Old Nov 9, 2013 | 03:12 PM
Thanks guys!
ComputerNerdBD
Mar 20, 2013 12:33 AM
Kaser1026
Dec 30, 2012 05:58 PM
Bluebeastblazer57
Aug 11, 2012 11:05 PM
BubbaBrooks
May 18, 2011 08:38 PM
TAZ454
Jan 28, 2008 10:11 AM
