ok...Whats the trick?
Which method is easiest for removing/replacing the motor mounts? Is it possible without taking out the engine? Whats the trick?
You gotta remove the motor mounts to get the engine out![Wink](https://blazerforum.com/forum/images/smilies/wink.gif)
The motor mount is a two piece thing. One is bolted to the motor the other is bolted to the frame. i only need to replace the piece bolted to the motor. There's a bolt that holds the two peices together, i have removed it but i cannot get the last bolt on the motor piece. i've already jacked the motor up as far as it will go with out taking it out, am i just going tohave to remove the engine for just one bolt
![](https://blazerforum.com/micons/m13.gif)
have you tried a 3/4" breaker bar on it with an ext if needed?
No i have not, i will try and see what happens.
mitch_houser
04-02-2012 06:28 AM
ldkronos
12-13-2007 03:54 PM
GMdesigner
06-22-2007 11:43 AM
