Question about door removal
Old Jan 23, 2006 | 06:44 PM
camohog1's Avatar
camohog1 is an unknown quantity at this point
Default Question about door removal
I was wondering if anyone knows how to get the window crank off the door so that the door panel can be removed. Thanks for the help guys.
Old Jan 23, 2006 | 07:32 PM
Default RE: Question about door removal
I don't know whether or not it would help to know the year/model of window crank you've got or not, but many times, they have a plastic snap ring inside that you just have to pry the crank off the splined shaft. They make special removal tools like this one -
Window Handle Removal Tool
to pry them off without damaging the door trim panel.
Old Jan 23, 2006 | 08:15 PM
camohog1's Avatar
it is a 1991 S-10 4.3 liter 2 door. It has manual locks and obviously manuel windows also.
Old Jan 24, 2006 | 03:32 AM
blazin97's Avatar
blazin97 is on a distinguished road
take a straight screw driver and push the door pannel back around the window crank and you should see a u shaped ring that goes around the window crank. You have to either pull it out with needle nose pliers(if you can fit them in there) or with a screw driver. then just pull the handle off, be careful not to loose that clip you have to put it back on the crank or it will keep falling off.
Nate_The_Great
Jan 1, 2012 11:23 AM
wolv2401
Feb 9, 2008 07:36 PM
blazerscooby
Feb 19, 2006 11:11 PM
pusher_sr
Jan 24, 2006 07:58 PM
john65807
Jan 7, 2006 11:31 AM
