Rear Defog Broken
Old Dec 16, 2009 | 10:42 PM
drummerdude's Avatar
drummerdude is on a distinguished road
Default Rear Defog Broken
so my rear window defogger no longer works. I know why, I replaced the lift shocks, but in the process the wires that have the clips on them, that clip on the shocks broke off both the window and the truck side. I tried re-soldering them, but the solder doesnt seem to stick to the wires. Was a special type of solder used originally? I can post pictures this weekend.
Old Dec 17, 2009 | 09:06 PM
fondo's Avatar
fondo has a little shameless behavior in the past
The piece on the end of the strut can be unscrewed off of the strut and you can attach an electrical eyelet connector. Then just crimp a piece of wire on it and crimp either a male or female (not sure which) connector on to that wire to plug into. Screw the piece back onto the strut and you should be good to go...
Old Dec 17, 2009 | 09:57 PM
The strut ends are fine, its the other ends, the plug and wire that connects to the truck and window.
Old Dec 17, 2009 | 11:34 PM
old skool luvr's Avatar
you need to purchase a "rear window defogger repair kit" from your local parts supplier, or any auto parts store.
if your location was in your info, i could point you in the right direction.
Old Dec 18, 2009 | 12:20 AM
LuvMyTJ's Avatar
Not sure if this is what you are describing but I had the male part that is soldered to the window come off on mine. I scuffed it up a bit, used a soldering gun and and solder and stuck it back on. It didn't want to stick to well, but I got it done. It is working fine again.
Old Dec 18, 2009 | 01:07 AM
i'm surprised the heat didn't "pop" the window, it is tempered.
Old Dec 18, 2009 | 12:02 PM
LuvMyTJ's Avatar
I was worried about that too, so after I was sure my insurance was paid up, I gave it a try. I didn't do a proper soldering job, just enough to get it to stick. I got the tab hot, melted a little solder on it, warmed the solder on the window a bit and then back to the tab. I then stuck it on while all was molted and held it there. I didn't think it was gonna stick, but it did. I carefully plugged it back in and it works. I just needed enough stick to make contact. It probably wont last a real long time, but if I get a couple years out of it, I will be happy.
Old Dec 20, 2009 | 10:24 PM
That's my concern too. Are there any shops that could do this for me? Can a dealer? Any thoughts?... oh and I'm located in the US, Pennsylvania specifically
Old Dec 20, 2009 | 10:48 PM
i've had success with those kits that you buy @ any parts store. i actually have to do my '98 sometime this week.
just follow the directions on the package, you shouldn't have any issues.
and when i mentioned about not knowing your location, it was a polite way of telling you to put the info in for your location (done in your "User CP"). we're not looking for an address, just your city/town & state. makes it easier if another member is around you to offer assistance, or info on a deal nearby.
let us know how you make out with the repair.
Old Dec 27, 2009 | 10:41 PM
tomwht's Avatar
tomwht is on a distinguished road
I repaired my rear defroster (93 S10 Blazer) by ordering a kit from frostfighter.com. They sell a conductive epoxy which works well--but it needs to be applied in a warm setting.
eyeblazin
Feb 7, 2011 09:55 AM
Blazers.B.Kewl
Jan 14, 2011 02:08 PM
Rags58
Jan 19, 2010 06:21 PM
fahzie
Sep 19, 2009 03:12 PM
stevelknievel
Aug 22, 2007 03:12 PM
