rear defog not working
Old Aug 22, 2007 | 12:49 AM
stevelknievel's Avatar
stevelknievel is an unknown quantity at this point
Default rear defog not working
ok i had to get a new back window for the jimmy and now the defogger doesnt work. does this mean i need a new window or is this problem easily solveable?
Old Aug 22, 2007 | 07:27 AM
junkmonkey's Avatar
junkmonkey is an unknown quantity at this point
Default RE: rear defog not working
Assuming it's connected properly, you may have a break in continuity through the grid. A simple test with a continuity tester should reveal that. It is possible to fix a break in the grid. I've seem a fix kit available whereby you locate the break, carefully scrape the ends of the grid where the break is and "paint" on a splice. The paint is obviously a conductive paint. Good Luck.
Old Aug 22, 2007 | 07:32 AM
You first should check for voltage at the rear window.
Old Aug 22, 2007 | 03:12 PM
well it worked fine before i replaced the window so im thinkin its the window...but ill check thanks guys
eyeblazin
Feb 7, 2011 09:55 AM
Blazers.B.Kewl
Jan 14, 2011 02:08 PM
Rags58
Jan 19, 2010 06:21 PM
drummerdude
Dec 27, 2009 10:41 PM
fahzie
Sep 19, 2009 03:12 PM
