Road Trippin
Old Aug 15, 2010 | 12:23 AM
sgp7679's Avatar
sgp7679 is on a distinguished road
Smile Road Trippin
So I took the ol' blaze on her first trip the other day and just got back tonight. Well the place was 2 hours away about 110 miles nonstop driving. She ran great except for front end wobble it get from 60-70 mph. Also anytime you are driving and hit any type of bump, you can hear what sounds like a jar of coins being shaken coming from the front end. Im thinking Im in need of front end rebuild? What causes the speed wobble? The lil' 2.8 ran great, there was a really REALLY steep hill I had to climb and that 2.8 struggled but made it. When I arrived at my destination 2 hours away, I noticed for example when I gas it to leave a red light, you can feel like 2 or 3 sumbtle pops, it not like when a u joint goes bad, it does it when your up to 5 going to 10 mph then runs smooth as butter again. Weird dunno what could be doing this. Any help on my questions is appreciated. O I almost forgot, highway mileage is GREAT!! filled her up at home and 2 hours later, tank was barley 1 mark under full! Im lovin' it!
Old Aug 16, 2010 | 12:44 PM
sgp7679's Avatar
any ideas on my little probs??
Old Aug 16, 2010 | 12:54 PM
rriddle3's Avatar
*Moved to '1st Gen Tech'*
You might have gotten a response already if this had been posted in the correct section. 'General Chat' is not for asking technical questions and some folks will just pass it by. Also, please put your vehicle information into your signature, so members won't have to search your old posts to find it.
Old Aug 16, 2010 | 12:56 PM
AJBert's Avatar
Could be a number of things. UCA/LCA bushings, tie rods, ball joints, idler/pitman arms, bearings/hub assembly, tbar bushings (if you have a 4X4), bad alignment, tires need balancing and the list can go on and on.
Either you need to crawl under there and start checking things out or have someone else do it. Replace what is bad and go from there.
Old Aug 16, 2010 | 10:15 PM
sgp7679's Avatar
ok it was sway bar bushings, replaced those and now front end sound is gone
TFisher
Feb 9, 2010 04:28 PM
blazer_in_ky
Nov 19, 2009 10:15 PM
Dabber
Sep 6, 2006 09:40 AM
Benado
Aug 30, 2006 12:05 AM
blazerrider101
Jun 3, 2006 08:19 PM
