trans trouble
Old Jan 20, 2007 | 12:42 AM
lylebig's Avatar
lylebig is an unknown quantity at this point
Default trans trouble
1994, 4.3engine. will not shift.no1st, 3rd, overdrive.2nd is all there is when in drive or overdrive or 1st, stays in second. also speedometer goes to 70mph when you stop, even when vehicle is shut off.I have never had a problem no slipage (nothing). any ideas
Old Jan 20, 2007 | 01:31 AM
lylebig's Avatar
Default RE: trans trouble
I guess i should add that reverse works fine and it goes into park. so i dont think the linkage is mess up.
Old Jan 20, 2007 | 01:36 AM
MNHawk's Avatar
MNHawk is an unknown quantity at this point
might be an issue with your valve body or a bad filter.
What color is the trany fluid? and does it smell burnt?
Old Jan 20, 2007 | 12:39 PM
lylebig's Avatar
color red. does not smell. I changed every 25000. due agin in 7000
Old Jan 20, 2007 | 01:01 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
Have you checked your fuses? I recall my Dad having the same issue with his 93. A fuse was blown and the trans is shifted by the ECM past the 1-2 shift. Korey.
Old Jan 20, 2007 | 10:29 PM
lylebig's Avatar
i have not checked fuses but i will tomorrow.
Old Jan 21, 2007 | 10:24 PM
HalJason's Avatar
HalJason is an unknown quantity at this point
No experience with the 94, but I know that the tranny did the same thing (stay in 2nd) and I had no spedo and my ABS went nuts when my VSS (Vehicle Speed Sensor) went out in the '95. VSS may be something to look into. A lot changed between 1994 and 1995, so someone more familiar with the earlier trucks may say otherwise.
-Hal
Old Jan 22, 2007 | 01:55 AM
1996BZR's Avatar
1996BZR is an unknown quantity at this point
I was thinkin the same thing about the VSS
Old Jan 30, 2007 | 04:37 PM
lylebig's Avatar
I just wanted to thank all that help.
It was the VSS (vehicle speed sensor).
auto zone wanted 57.00 pruchased from the dealer for 42.00 imagine that, has to be a first.
Greg
Hurm2006
Feb 16, 2013 10:57 AM
grounded87
Jul 1, 2011 11:22 AM
rob1621
Feb 29, 2008 08:15 PM
thevair65
Nov 12, 2007 12:01 AM
kevinfugate2005
Sep 3, 2006 04:37 AM
