Vent blower stuck on floor
Old May 31, 2011 | 01:58 AM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
It's actually a vacuum actuator (you have 4). changeProbably the toughest one to change but if you're not afraid of a little work go for it. If you are get a hacksaw blade.
Old May 31, 2011 | 06:32 AM
warthogdriver's Avatar
if its the damper then you can access it thru the floor vent itself.
remove the lower center console...then remove the plastic divert-er for the floor vent...it just pops out...then you should be able to get your hand up inside there and swap it out....i actually cut some holes and learned of this method to late.
if you search around there is a more descriptive write up somewhere.
Old May 31, 2011 | 10:21 PM
burning_soul07's Avatar
burning_soul07 is on a distinguished road
Right behind the kick panel in the center on mine there is a little metal switch that goes back and forth. It switches floor on and off. Take the kick panel off and youll see it.
Old Jun 4, 2011 | 12:28 AM
If you have a hand held vacuum pump like a Mity-Vac you can test the actuators individually and the whole system at once. Invaluable tool.
Old Jun 11, 2011 | 12:18 AM
Just have to test them> A hand held vacuum source like a Mity-Vac works great for this.
MJKH84
Feb 22, 2015 07:02 PM
Sam Ford
Feb 2, 2013 07:47 PM
contour1
Jan 3, 2011 04:36 AM
sinnervision
Nov 27, 2010 08:29 AM
starcruiser
Oct 17, 2009 10:52 AM
