what size?
Old Nov 16, 2009 | 02:45 PM
tony991's Avatar
tony991 is on a distinguished road
Default what size?
What size nut is on the front axle that helps hold the hub assembly on (not the three nuts behind the hub assembly but the big one in the center) Tried searching for it in the forum but couldnt find it...
Old Nov 16, 2009 | 03:09 PM
ABN31B's Avatar
i want to say 35mm. Might be different for the older models (1st gen, early 2 gens, 2 doors, 2wd, etc) though. I don't know what yours is, but i have a 2000 4x4x4.
Old Nov 16, 2009 | 03:38 PM
axle nut size...
Search term was "axle nut" keeping the quotes.
Old Nov 16, 2009 | 04:53 PM
tony991's Avatar
oh ok.. Thanks guys.. didn't know i needed to put the quotes when i use the search...
Old Nov 16, 2009 | 09:24 PM
Check out the link in my signature for more inventive ways of using the search function. It is quite capable!
Old Nov 17, 2009 | 01:07 AM
ABN31B's Avatar
boo! I was off by 1 MM
if you got the 35mm socket, just get a hammer and an impact wrench.... it will work
BONUS: It's shiney now!
Old Nov 17, 2009 | 06:12 AM
Actually, a 35mm socket will work. Check out the discussion in the thread I linked to. The 35mm will fit more tightly onto the nut, but it really is not a 35mm nut.
Old Nov 17, 2009 | 10:51 PM
ABN31B's Avatar
Interesting. So my nuts are corroded. *cue rim shot*
good to know either way. Should have read through more I suppose.
Old Nov 18, 2009 | 05:55 AM
Not necessarily.
The 36mm nut is actually 35.5mm flat to flat. The 36mm socket is 36.5mm flat to flat. Per machinery's handbook, this is an acceptable tolerance. 1mm clearance is only 0.040" and for a fastener this large, that will not allow the proper 36mm socket to strip over.
The 35mm socket is actually 35.5mm flat to flat. Being line to line, nut to socket, it would fit a bit snug at best, but may not fit for everyone at worst.
Old Nov 19, 2009 | 12:34 AM
old skool luvr's Avatar
that's 'cause you drove into that soup @ WOT!!
there's probably more reasons why, but this is a family forum, so we'll just leave them alone-wait...isn't that how they got corroded in the first place *ba-dum-dum, tisssss*
BackwoodsBogger14
Headers, Intake, & Exhaust
Oct 8, 2013 12:20 AM
mx_579
Tires and Wheels
Sep 18, 2009 11:36 AM
zero psi
Suspension Tech
Mar 10, 2005 10:30 PM
zero psi
Feb 3, 2005 05:57 PM
Wolf~K5
Dec 13, 2004 11:05 PM
