Where is the Knock Sensor?
Old Feb 20, 2013 | 08:41 PM
RexCastle's Avatar
RexCastle is on a distinguished road
Default Where is the Knock Sensor?
i have a 89 4.3 S10. Does anyone have a photo of where it is because i cant find it in my chilton
Old Feb 20, 2013 | 08:53 PM
mr.vls's Avatar
It is attached to the back of the engine to the left of the distributer kind of low. I replaced my knock sensor on my 89 Jimmy last year and I had very difficult time removing. I ended up removing the throttle bracket assy. and the distributer to get more access. The problem I had was that I could not get a solid grip on it to get it to unthread it from the back of the engine. I hope you have an easier time than I did.
Old Feb 20, 2013 | 08:59 PM
RexCastle's Avatar
was it not accessible from under the truck?
Old Feb 20, 2013 | 09:15 PM
chris015's Avatar
its either on the drive side head,or back behind the engine.
Old Feb 21, 2013 | 06:17 AM
mr.vls's Avatar
No you cannot get at it from underneath due to the bel housing and firewall.
Old Feb 21, 2013 | 06:53 AM
neo71665's Avatar
If you have a body lift its not as bad from under it.
Old Feb 23, 2013 | 11:06 PM
ohsofly's Avatar
Yup pull out your distributor and you will see it. Stick a rag in the distributor hole so no crap falls in there. Mark the dist before you pull it so you can put it back the same, and don't rotate it when its out.
fredguaz
Dec 11, 2017 08:11 AM
ejschultz
May 23, 2009 04:15 PM
deadpool
Apr 2, 2006 06:09 AM
getblazed00
Feb 12, 2006 11:20 PM
dwoftx
Jul 10, 2005 06:47 PM
