Wont Start????
Wont Start????
I have an 87 S10 Blazer it wont crank it sounds like a bad battery or starter when u turn the key there is nothing, replaced battery, starter, alternator, cables, and checked grounds. Still wont start any advice would be great
Does the starter even try?
Does it try but nothing?
If it tries, does it have spark and fuel?
Even if it has spark, are the plugs clean?
If it doesn't even try, can you jump the starter by hand to try it that way?
Maybe theres a wiring issue in the column to the computer...
Too many variables.
Too many variables.
no it seems like their is no power going to the starter acting like a dead battery
it gets spark good plugs
dunno about fuel havent checked
i have jumped the starter and its good i blew though 2 of them since it was burning them out
i know it must be some electrical issues but dont know where to begin
Try turning your lights on and hitting the starter switch, if they go real dim you've either got a short in the starter circuit, a bad battery, motor's locked up, or the starter is shorted.
i wish i could hit the switch and see if the headlights dim but i have no headlights they dont even turn on but the tail and brake lights work
bad relay or short in the ground to body or the switch is bad
Check the cable that goes from the engine to the chassis and the ground from the body to the chassis. If those are gone or broken, it'll seem like it's completely dead.
JimmyBlaze541
05-02-2013 10:00 AM
bobby099
15
11-07-2012 07:29 PM
FreeTime
09-08-2012 01:38 AM
slammed95blazer
10-27-2010 07:24 AM
jetsmy
08-01-2008 10:10 PM
