works when it wants to
Old Mar 26, 2008 | 09:52 PM
blaze93's Avatar
blaze93 is an unknown quantity at this point
Default works when it wants to
Hey all! I have a 93 blazer push botton4x4 that engauges into 4 wheel when it wants to, some time it works some times it dont, anyone have any ideas what the problem is? Also is it possible to switch a push botton to a manual shift on the floor? Thanks bunch!
Old Mar 27, 2008 | 09:25 AM
94blazer4.3ho's Avatar
94blazer4.3ho is an unknown quantity at this point
Default RE: works when it wants to
push four high/low andcheck if the front drive shaft is locked orsill loose if it is still loose i would start with the encoder motor.
do a vaccumm check at the back of the intake manifold.
do a vaccum check at the front acuator, when trying to put it in to four hi. Should be about the same pressure. if the drive shaft locks and there is the proper pressure id replace the front diffirential acuator if there is no pressure id replace the vaccum switch on top of the transfer case
[IMG]local://upfiles/7456/72DAEF49F1E4497380E6FB750D80CCDC.jpg[/IMG]
TheDevilsDaddy
Sep 6, 2015 10:28 AM
FsTFwRd
Oct 9, 2011 06:27 PM
ExplicitYourSelf
Mar 30, 2010 08:04 PM
ExplicitYourSelf
Mar 23, 2010 07:17 PM
Frosty
Mar 3, 2008 12:58 PM
