Brake Bleeding.......no fluid coming out.
Old 04-23-2007, 11:09 AM
97Blazer15's Avatar
97Blazer15 is an unknown quantity at this point
Default Brake Bleeding.......no fluid coming out.
Hello, I have a 97 Blazer with rear drum brakes. I was a attempting a brake fluid flush this past weekend, using aMotive pressure pump. All is going well, I did the rear passenger first and then when I went to do the rear driver side, I opened the bleeder screw yet nothing came out. I made sure the pump was still under pressure no higher than 8psi. What gives? I even took out the screw completely. Could the line be clogged? How can I resolve this? Thanks
Old 04-23-2007, 04:23 PM
pilgrim's Avatar
pilgrim is an unknown quantity at this point
Default RE: Brake Bleeding.......no fluid coming out.
I'd try it with a human foot on the pedal first, applying more pressure.
If no joy, either erbuild or replace the brake cylinder. They're not expensive. Then bleed.
The benefit: brake fluid should be replaced every 2-4 years anyway, so you're due.
Old 04-24-2007, 04:14 AM
Chevy Lover's Avatar
Another thing you could try is bleeding a front caliper to see if the fluid come out there. If that works, kick the brake pedal a couple of times, with the bleeder closed and try the other rear. It's possible that you have tripped the equalizer valve.
Old 04-25-2007, 01:28 PM
pilgrim's Avatar
Good point. I still haven't sorted out the behavior of equalizer valves. But not getting fluid out of a brake caliper or cylinder is "Bad".
Old 04-26-2007, 06:15 PM
97Blazer15's Avatar
Thanks for the responses, I will replace both rear cylinders and yes cheaper than I thought, rockauto.com has great prices if any of you are interested. They just emailed me a 5% discount code that's good for a few weeks. 643348581870 enjoy. Insert code in "how did you hear about us"
Old 04-26-2007, 07:21 PM
pilgrim's Avatar
Hint: when you take apart the rear brake to replace the cylinder, do ONE side at a time. Then if you forget where the pieces go, you can pop the drum off the other side and you have a handy reference.
luthers97blazer
11-10-2008 01:27 PM
portcqb
03-13-2008 04:25 PM
jess1327
03-12-2008 11:37 AM
Hanr3
11-23-2007 08:26 PM
Dj7763
03-10-2007 10:41 PM
Quick Reply: Brake Bleeding.......no fluid coming out.
