Can the timing cover be reused?
Old 04-20-2012, 10:53 PM
Klturi421's Avatar
Klturi421 is on a distinguished road
Default Can the timing cover be reused?
I have not yet removed my timing cover as I fear that I cannot find one locally to pop back on.
The front of the cover says to replace once removed (using a loose term). Im curious, could it in fact be reused or is it best to try and find a new one and replace it then?
Old 04-20-2012, 11:50 PM
neo71665's Avatar
If its plastic personally I use a new one. If its metal you can get away only swapping the seal. I know of people that reuse them but I wouldn't chance it. They are covered, not easy to get to, and plastic gets brittle under heat and age.
Ya might be lucky and a metal one fits it. Gotta count the bolt holes and make sure. I know there were different versions depending on where the engine was made.
Old 04-21-2012, 12:50 AM
Jase1979's Avatar
Jase1979 is on a distinguished road
Dorman products sells them for under $40 safer to replace it for that price
Old 04-21-2012, 08:23 AM
GM "dealer issue" factory shop manual says if the cover is removed DO NOT reuse it. The crankshaft position sensor relearn MUST be performed if the timing cover and or crankshaft position sensor is moved, removed, disturbed or replaced. Code readers are not capable of performing the relearn, it must be done with a capable scan tool.
Old 04-21-2012, 03:27 PM
NVANZEE's Avatar
Just replace in. they dont cost much at all. It might be ok to reuse it buy why take the risk.
Old 04-21-2012, 04:50 PM
dano440's Avatar
dano440 is on a distinguished road
is it possible to change them with out removing or loosing the oil pan? I have been thinking I should replace my timing chain and gears but have been putting it off.
Old 04-21-2012, 05:17 PM
Klturi421's Avatar
That's actually what I am trying to figure out myself. I was able to successfully remove the cover without removing or even unbolting the oil pan, I am however having difficulty with the installation process.
Either this evening or tomorrow I am probably going to drop the pan a little and stick it on. It doesn't seem like it has to come completely off, just unbolted enough to slip the cover on.
Old 04-21-2012, 05:56 PM
dano440's Avatar
let us know how that works out. I might try mine later on in June
Old 04-21-2012, 08:18 PM
Jase1979's Avatar
I have replaced at least 50 of these timing covers on 2wd and 4wd. It is possible to change it without removing the oil pan, BUT very difficult to get the cover in and aligned properly, What I do is remove 2 oil pan bolts 1 on each side in the center of the oil pan,. Then I use a longer bolt and start it in them 2 spots. Next remove the rest of the oil pan bolts and let the oil pan rest on the longer bolts remove and replace cover, reinstall oil pan. Should also mention that you have trans lines and oil cooler lines bolted to the pan that also need to be unbolted to lower the pan
user3657
11-22-2009 04:46 AM
black95blazer
01-30-2008 05:01 PM
kgould67
10-16-2007 12:49 PM
frankjc
08-07-2006 11:12 AM
Quick Reply: Can the timing cover be reused?
