" co" codes 6 of them
co265,co236,co237,co281,co222,co226 all abs codes , i know i have a rt rear brake problem. But wth. And i also have a co128 low coolent temp. Yes i pulled my t-stat so it would run cooler in the sand. Any comments ?? Would be help full. Thanks larry r
The first 6 codes you mention are brake codes. Check the ABS sensors on the wheels. Clean them and check the ground wire connections.
The last code you mention is a low brake fluid warning code. For it to be low coolant temp code it would be P0128, not C0128. Plus, if you removed the thermostat then you already know why you would get a low coolant temperature warning.
In all the codes the second character is a '0' (zero), not the letter 'o'.
abadinalbany
04-16-2011 11:31 AM
stanitis
11-27-2010 11:10 PM
