fuel gauge reads more than full
i guys i just bought an oldsmobile ravada 97 wth the 4.3 engine. Im havingthis problem with my gauge always reading more than full tank, i tried disconecting the fuel sender unit to check if it was the floater thing but evend do i disconnected everything even the fuel pump the gauge goes up. Im erally lost here so any input would be greatly appreciated. thanks
Your gauge could be bad or you could have a bad wire between the sender and the PCM/BCM.
i already replaced the istrument panel and it does the same thing. how do i check for a bad wire.. do it do it just phisically or check resistance??? where is the ecm or pcm that you mentioned
so i found some more symptoms... if you turn off the car the needle goes to like 1/4 of gauge but *** soon as you start the car the needle goes up.
Blessed23
09-27-2014 06:50 AM
BlakeM
06-23-2011 06:18 AM
fallen4her02
04-24-2011 09:37 AM
Olds Guy
11-11-2010 09:21 PM
blazerguy22
12-12-2008 07:59 PM
