No primary voltage need schematics
Old 08-30-2010, 07:24 PM
big_windy's Avatar
big_windy is on a distinguished road
Default No primary voltage need schematics
Can anyone help me get the ignition chematics for a 4.3ltr 2000 blazer with EDI ignition?
I just changed the timing chain and gears on the truck, and may have wiring problems because I had to raise the engine to remove the pan. Any help will be welcomed, Thanks.
Old 08-30-2010, 08:50 PM
What parts of the ignition system do you require schematics for. My references have it split up by sensor, etc, not a whole system diagram...
Also, you could always consider a subscription to AllDataDIY.com.
Old 08-31-2010, 07:12 AM
big_windy's Avatar
I'm interested in harness from Crank positioning sensor and coil/control to PCM. I'd like to check for voltage/ohms in these wires.
Old 08-31-2010, 10:57 AM
I was able to locate one diagram that has all of this in it.
Attached Thumbnails No primary voltage need schematics-2000_ignition_sch.gif
Old 09-01-2010, 06:54 AM
big_windy's Avatar
Super! Gotta work today, but will hit the garage tonight to begin troubleshooting. Suspect the PCM is going, but had no codes to that direction. I figured with the amount of miles, it'd be a safe bet the timing needed a going through.
Man, that was a tough job!
Thanks Swarty!
aftermath8966
07-22-2014 04:05 AM
2001Blue
12-31-2010 12:16 PM
MrMopar+GM
09-01-2010 08:35 PM
Schrade
03-16-2010 02:42 PM
OhOhBlazer
07-16-2009 07:34 AM
Quick Reply: No primary voltage need schematics
