quick tip - popping multi port spider injectors (newer style) out of manifold
Old May 6, 2014 | 07:44 PM
Cool quick tip - popping multi port spider injectors (newer style) out of manifold
I'm sure there's other methods out there, but I pulled my manifold apart today and discovered an easy way that requires no special tools at all. Well, the only "special tool" is a bolt and nut that holds the throttle body to the upper manifold
The one of the front two bolts that holds the throttle body on, with the extra nut on it that holds the bracket for the throttle cable. Take the nut and thread it a little onto the longer threaded end of the bolt.
Now just take that end and place it into the plastic nozzle in the intake runner. Make sure the threaded on nut buts up to the nozzle flat. Also make sure that you don't thread the nut on so far so that the bolt contacts the injector. All you want to do is have the nut but up flatly against the plastic nozzle.
Now using something like a ratchet or large wrench, give the bolt a few firm taps. It doesn't take much (you don't need to use anything like a hammer...), the injector will pop out and come out the top side of the manifold.
Attached Thumbnails quick tip - popping multi port spider injectors (newer style) out of manifold-img_20140506_180331.jpg   quick tip - popping multi port spider injectors (newer style) out of manifold-img_20140506_180348.jpg   quick tip - popping multi port spider injectors (newer style) out of manifold-img_20140506_180411.jpg   quick tip - popping multi port spider injectors (newer style) out of manifold-img_20140506_180423.jpg
Old May 7, 2014 | 08:02 AM
LannyL81's Avatar
Great tip..no pun intended there. I was not able to get these out when I did the LIM gasket change about a year ago. I was fearful of breaking the injector nozzle so did not try anything like this.
What is the locking mechanism the holds each injector nozzle in the intake anyways?
Old May 7, 2014 | 08:10 AM
not much, just a couple little flared out "prongs" around the injector. When I get home this afternoon I'll snap a couple pictures before I put the cleaned up assembly back together
Old May 7, 2014 | 07:28 PM
all that holds it in is 3 small protrusions around the injector
by the way, a little carb cleaner goes a LONG way on the spider assembly when it come to cleaning them up
Attached Thumbnails quick tip - popping multi port spider injectors (newer style) out of manifold-img_20140507_182714.jpg   quick tip - popping multi port spider injectors (newer style) out of manifold-img_20140507_182706.jpg
Old Apr 19, 2015 | 02:44 PM
Pale Horse's Avatar
Pale Horse is on a distinguished road
I hate to bump an old thread, but I actually broke one of the plastic tips while removing the MPFI assembly. Does anyone have any extra they could sell me? I realize it would hardly be worth your time for its worth, but it would greatly help me out.
ChevyBlazer4uHaters
Jan 9, 2014 03:39 AM
Peak Speed Shop
Performance & Brainstorming
14
Jun 26, 2013 09:16 PM
nineteensixtycaddy
Apr 16, 2010 07:27 AM
mike97blazer2DR
Jul 4, 2005 11:10 AM
v8only
Jun 29, 2005 06:02 AM
