Still leaking!
Still leaking!
I have a 1998 8S 10 blazer 4 x 4. We’ve had the fuel pump replaced twice and the gas lines checked and also the fuel fill spout. However when I fill it up with gas it still leaks. We have checked everything and I can’t find nothing else I am at a loss. Help
If that plastic fitting the others have mentioned is not broken.
Have you checked to make sure the round rubber seal for the pump is sealing correctly?
I had a bad experience with a cheap aftermarket gasket.
On a 97 4 door that i used to own i changed the fuel pump and it leaked bad when full so i dropped the tank and pulled the pump back out twice before i finally put the seal that came with the pump next to a factory GM seal and the aftermarket one was a slightly different diameter. I then reinstalled the aftermarket fuel pump with a GM gasket and it never leaked again.
er0ck273
26
06-05-2013 07:14 PM
vmx120
09-12-2005 07:10 PM
