Sway Bar Linkage, help???
Old Apr 8, 2013 | 11:56 AM
hitman2988's Avatar
hitman2988 is on a distinguished road
Default Sway Bar Linkage, help???
so I replaced the bold and bushings on each side,, but it looks like the is allot of play in between bushings? Is this correct,, or is it a nice snug, tight fit??
a little more info,, I bought the set at Autozone, and this is on my 2001 ZR2
Old Apr 8, 2013 | 12:13 PM
El_Beautor's Avatar
It should be snug. The bolts should be tightened down until the bushings just start to squish/bulge. Don't over tighten them or the bushings will split. You want it to be just snug.
Old Apr 8, 2013 | 02:20 PM
Diaita's Avatar
Do you have a picture?
Old Apr 9, 2013 | 01:06 AM
Spree's Avatar
Spree is on a distinguished road
Ya...give us a pic!
Old Apr 9, 2013 | 09:55 AM
El_Beautor's Avatar
These aren't my pictures, because I don't want to go crawl in the snow to take any of mine. They're from this thread. For some reason his bolt is too long, but it should give you a visual of what the bushings should look like. Once they just barely start to bulge on the sides stop tightening.
***EDIT***
I knew Rexmburns had pictures somewhere but I gave up too soon. Here's a link to his build thread where he did a quick disconnect on his sway bar, and you can see the urethane bushings tightened down. Hope he doesn't mind my borrowing his pictures!
Well I managed to get some quick disconnects made for the front sway bar. I still have to make something to hold it out of the way when disconnected but my factory bushings and bolts were shot so I figured I would go ahead and make these instead just replacing them with regular bolts and washers.
Heres some pics if you have questions ask
Compared to the old that I had to cut off!
And installed
Attached Thumbnails Sway Bar Linkage, help???-pc0bxl.jpg   Sway Bar Linkage, help???-hibk4l.jpg   Sway Bar Linkage, help???-imag1331.jpg   Sway Bar Linkage, help???-imag1332.jpg
WildDomesticTabby
May 21, 2014 06:17 PM
LilPudge666
May 4, 2012 12:34 PM
Twiztidly
Oct 1, 2011 10:43 PM
heypops
Nov 1, 2010 11:19 AM
timetoblaze
Suspension Tech
Oct 30, 2005 12:17 PM
