[electrical][AC] Blower motor question
Old Apr 3, 2014 | 07:49 PM
xboarder56's Avatar
xboarder56 is on a distinguished road
Post [electrical][AC] Blower motor question
So my ac is constently blowing fuses so I test the continuity and found 2 pins that give me a beep I took a picture of it but its the plug that plugs in the blower motor. Kinda knew to car repair and everything so was just trying to work through it myself. The ac will run for a while then blow the 20amp fuse in the side of the dash. I found a total of 3 plugs that plug into the main ac system then like 2 into the blower motor section.
Would that be all the plugs that I would check for??
I attached the pictures below, if you guys have anyother input or some guess i can take more pictures and even a video if you would like. Let me know and thanks everyone for your help and knowledge!!!
Attached Thumbnails [electrical][AC] Blower motor question-20140403_151700-copy.jpg   [electrical][AC] Blower motor question-20140403_151709-copy.jpg   [electrical][AC] Blower motor question-20140403_151154-copy.jpg
Old Apr 3, 2014 | 10:10 PM
What is the year and model? Manual HVAC, not automatic climate control, is that correct? The first & second images are the blower motor resistor. The third one is the clutch cycling switch. What number is next to the fuse in the fuse panel? Does the blower stop working or does the compressor clutch stop engaging?
Old Apr 3, 2014 | 11:13 PM
xboarder56's Avatar
So its a 1996 chevy blazer 4.3L 4x4, the hvac not sure in manual or automatic is their something i can look at to tell me? Compressor seems to be the problem but i belive the reason it stops is due to the fuse blowing all the time.
The fuse is the ac compressor fuse 10amp fuse.
the first picture shows the arrows of the 2 points i checked with the multimeter that im guessing that the short is comming from causing the fuse to blow but not totally sure.
thanks for the help captain
Old Apr 4, 2014 | 02:44 PM
In your images, the plug with 4 wires is for the blower resistor. Totally seperate circuit from the A/C clutch, (that's not the problem).
Automatic climate control has degree markings around the temperature selector dial, manual HVAC does not.
Unplug the A/C compressor clutch electrical connector located right next to the compressor pulley. The connector has two wires: dark green and black. Make sure the fuse is good. Turn the mode switch to MAX A/C, and drive the vehicle. See if the fuse blows. If it does not, the clutch field is shorted and needs replacement. Post your results.
Old Apr 6, 2014 | 12:47 PM
xboarder56's Avatar
So I believe the circuit that is bad is the one that plus into the a.c. tank where you put he r134a into I unplugged the sensor over their ac has been running for 2 days now.
Old Apr 6, 2014 | 09:29 PM
If you unplug the cycling switch, (the switch the accumulator) the compresor clutch should not/will not engage. If it does, there's a short elsewhere in the circuit.
maxvamp
Oct 31, 2020 08:19 AM
Tajohns34
Jan 19, 2015 08:17 AM
XIonRAILS
Jan 22, 2014 10:41 PM
DaveRush
Oct 12, 2011 11:10 PM
SWATPARAMEDIC
Jan 1, 2010 03:12 PM
