01 Blazer, stuck in 4wd low
Old Aug 26, 2010 | 07:03 PM
BEAT MY JIMMY's Avatar
BEAT MY JIMMY is an unknown quantity at this point
Default 01 Blazer, stuck in 4wd low
My 01 blazer is stuck in 4wd low. It's my daily driver so I'm kinda screwed, any ideas? thanks.
Old Aug 27, 2010 | 07:12 AM
Flatearthman's Avatar
Flatearthman is on a distinguished road
more info please.
does the 4wd switch light flash when you push any of the buttons?
can you hear the relays click?
is the service 4wd light lit up on the dash?
Old Aug 27, 2010 | 11:26 AM
1998MSO's Avatar
1998MSO is on a distinguished road
Just to confirm.....you do know the procedure for shifting out of 4lo correct? You must stop the car, shift into neutral and then press the 4hi button.
Old Aug 27, 2010 | 11:11 PM
The service 4WD light is not on. When it's stuck in 4 low, the 4 low light is on solid. When I press any of the other buttons (4 high, 2 high, or auto 4WD), the light for that selection will flash, the relays make noise, and it sounds like it's trying to engage (noise from the front axle), but it will go back to 4 low, with the 4 low light on solid. And yes, I do know the procedure for changing in and out of 4WD.
Old Aug 27, 2010 | 11:30 PM
DKSDAD's Avatar
Rob it could be the encoder motor but I am not sure. I will ask tomorrow at work but the tech I would really want to speak to is off on Saturdays. I will let you know what I find out. It could also be the TCCM. I will ask tomorrow. Sorry that sucks no matter how you look at it. Also, were you supposed to go wheeling with the club this weekend?
Old Aug 29, 2010 | 12:36 AM
DKSDAD's Avatar
Rob, I asked one of the guys at work and he said either encoder like I said or TCCM like I thought. I hope this helps. Talk to you soon.
Streetracer94
Oct 29, 2018 09:33 AM
lac8362
Nov 2, 2011 08:15 AM
aspenrebel
Dec 12, 2007 05:52 PM
Mikes1Addiction
Jan 12, 2007 02:08 PM
bcmaxx
May 8, 2006 06:59 PM
