01 rough idle at start but goes away....
so my 01 has a rough idle, almost a miss when i first start it and if i go drive it around it will go away, and not come back untill i leave it and try starting it again once its cold,
i've maybe driven it 3 times in the past 6 months, did a fresh oil change(noticed a bit of sludge) ran some seafoam, changed again, still nothing...
any suggestions?
any suggestions?
my 99 did the same thing check your throttle body right where the valve is to let air in. it could be built up with carbon so the valve is having a little trouble opening and closing. i cleaned it and the problem seemed to go away
Yes, I have seen it numerous times... the cap shorts itself out within the plastic causing a misfire that can barely be heard but does throw a code usually and cant be heard with the rpms high. replace them with ac/ delco parts ONLY if you have the cash to.
fletch125
Jun 10, 2014 12:59 PM
jmac219
Aug 27, 2011 03:42 PM
CrashPro993
Nov 8, 2007 04:32 PM
liblrogers
Jan 2, 2007 08:41 PM
