01 S10 Blazer Hood
Old Mar 12, 2008 | 05:16 PM
78corvette's Avatar
78corvette is an unknown quantity at this point
Default 01 S10 Blazer Hood
I went to put window cleaner in my truck and the latch inside wouldn't work.
How do you get under the hood if the latch won't release from inside?
Old Mar 12, 2008 | 05:32 PM
WolfPack's Avatar
Default RE: 01 S10 Blazer Hood
Start off gentle, and push down on the front of the hood right by the latch. Also try lifting up as far as possible on the hood then going and pulling inside release.
If that doesn't work...try a bit more 'finesse'. Mine would release with a well placed pound on the drivers side hinge-ish area of the hood. Once you get the hood up, spray a WHOLLEEE lot of wd-40 or some other cleaner all over the latch mechanism to clean it out and grease it up.
Shouldn't have any problems after that!
Old Mar 13, 2008 | 01:52 PM
garry2000blazer's Avatar
garry2000blazer is an unknown quantity at this point
Does the latch release handlemove when you pull on it...or move without much resistance? Might be a frozen or broken release cable.
2000BlackBeauty
May 26, 2013 05:51 AM
ChevyMane808
Apr 5, 2013 10:51 AM
sprbld417
Apr 25, 2011 07:28 PM
Scream And Fly
Aug 26, 2006 12:25 AM
