01 S10 v6.. A few things...
I posted this on a different site, but there isn't much action there. Maybe you guys can help.
My brother in-law took his truck in to have a leak checked out. They told him the following:
Oil cooler pipes on tranny leaking (non 4x4)$440
Lower intake mani (gasket?)leaking coolant+replacet-stat$500
Front+Rear shocks leaking $400
I told him not to have any of the work done because thats a lot of money, and mostly in labor. I build and tune Audi/VW cars and have all kinds of experience and tools. I'm just wondering if after I verify this diagnosis to be true, are there any relatedDIY articles floating around here mainly for the tranny cooler and intake mani? Are these normal issues with these engines at ~70k miles?
I didn't see anything in the DIY section other than some fault code definitions.\
Thanks.
Thanks.
RE: 01 S10 v6.. A few things...
A good DIY article from D-tips has been posted quite a few times for the intake manifold gaskets.
4.3L Intake Manifold Gasket Replacement - DTips.com
As far as the transmission cooler lines, there is nothing special about them other than how they connect to the transmission. They clip into a special fitting that can be fun to deal with. I would recommend you find the area where the leak is, then cut the line and sleeve it with some rubber hose & hose clamps. Just make sure that the rubber hose is compatible with the temperature and transmission fluid.
travisrussell88
10-20-2011 10:16 PM
scott_wheels
01-26-2010 05:49 PM
82blazerchick
04-14-2009 02:57 PM
