01 Trailer Lights
Old May 18, 2010 | 07:55 PM
A/M/G's Avatar
A/M/G is on a distinguished road
Default 01 Trailer Lights
I have searched the forum and a I cannot find the answer.
01 blazer, wanting to add trailer lights. Rear bumper, cross member, found a bundle that has a disconnect, (mentioned in a from a previous thread). Disconnected it, all lights still work except the license plate lights and I got a service eng soon light.
I see where it goes to the license plate light, but cannot see anything else.
Is there a connector for the brake and turn signals? If so, please give an approx location.
Thanks
A/M/G
Old May 18, 2010 | 07:59 PM
Not sure what you were searching for... Posted in quite a few threads...
Examples from a search for "trailer+wiring":
How do you know if you have the Tow Package?
Trailer light harness
There should be a bundle of wires towards the driver side of the rear cross member that has a bunch of cut wires in it. This is the stock trailer harness. The number of wires depends on whether it is the standard light duty harness or the optional heavy duty harness. Your RPO codes will define which you should have.
Old May 19, 2010 | 07:15 AM
A/M/G's Avatar
I had previously read the above post, I do not have a tow package. I do not see any wires tucked under the bumper that have no terminal ends on them. The rear cross member only had one connector the one I mentioned.
Thanks
A/M/G
Old May 19, 2010 | 11:24 AM
You aren't looking for a connector at all. You are looking for a bundle of wires. If you do not have them, then you will have to get a splice kit. Most autoparts stores can get them. They will splice into the brake/turn wiring harness. They should come with the applicable instructions for installation.
Philipx
Dec 14, 2015 04:29 PM
bobbya55
Aug 9, 2009 06:49 PM
Boyer2011
Jul 29, 2009 02:02 PM
blazermayne87
Jul 13, 2009 02:15 AM
Kellen
Oct 10, 2007 06:48 AM
