03 Blazer- starts but dies immediatly. please help!!
Old Mar 5, 2011 | 11:01 PM
avelate63's Avatar
avelate63 is on a distinguished road
Question 03 Blazer- starts but dies immediatly. please help!!
hi, i recently bought an 03 blazer 2 door and i'm brand new to this forum.. recently i was attempting to install a new deck and audio set up in it. i kept having problems getting the wiring correct so i think i got wrong wiring diagrams.. ugh. but main problem is that after i gave up i went to start it and it will crank and start up no prob with the key but dies as soon as starter disengages... i'm thinking fuel pump, or at least some sort of problem with fuel pressure. any ideas thought???
thanks a ton..
Old Mar 6, 2011 | 08:14 AM
ffox's Avatar
ffox is on a distinguished road
Did you do any wiring around the ignition switch? Sounds like maybe the ignition run wire "Ignition 2" problem to me.
Here's the colors on the ignition switch. The white wire is the one I think is the problem. It supplies voltage to the coil in the RUN position.
82-93 S-10 or blazer
12volts red (there will be 2) + ignition harness
Starter yellow or purple + ignition harness
Ignition pink + ignition harness
Second Ignition white + ignition harness
Accessory orange + ignition harness
Second Accessory brown + ignition harness
Old Mar 8, 2011 | 09:21 PM
avelate63's Avatar
ok i think you might be right but thing is it's an 03 so colors are def differnt.. there's no white. i'm thinkin i need an immobilizer bypass module?? ugh confused..
Old Mar 9, 2011 | 10:30 PM
avelate63's Avatar
ok so i played with it and figured out one of those wires were connected with the ignition switch. thanks a ton!!
tim317296
Jun 30, 2013 07:59 PM
teammartinez06
Dec 13, 2011 07:20 PM
6cap6tech6
Aug 26, 2011 07:07 AM
Blazer Will
Dec 13, 2009 06:22 PM
Brother_dave
Sep 25, 2008 06:20 PM
