0452 code..hard start
Old Jan 3, 2012 | 05:10 PM
tazman's Avatar
tazman is on a distinguished road
Default 0452 code..hard start
blazer threw an 0452 code..i know what it is but it also has a very hard start..4-10 crank times to get engine running..this is only when it is cold out. when it does get started the engine sounds and feels like a have a jack hammer under the hood..takes about 20 min for it to smooth out..miss fire?...or does the fuel pressure sensor have to do with starving the engine?...or would it be the spider injectors under cold situations?
Old Jan 6, 2012 | 03:18 PM
tazman's Avatar
bump.
Old Jan 6, 2012 | 05:57 PM
The P0452 is an EVAP problem not related to the extended cranking problem. This engine does not have a "fuel pressure sensor" however; Checking fuel pressure and leakdown should be the first thing you check. Key ON, engine OFF, fuel pump running, pressure must be 60psi to 66psi and must remain above 55psi for 10 minutes after the pump shuts off. Post your results.
Old Jan 6, 2012 | 06:07 PM
xgiovannix12's Avatar
this might help you if you need any more information on the test captains talking about
96+ Fuel System Diagnosis - Blazer Forum - Chevy Blazer Forums
Kevin Gore
Dec 13, 2013 09:35 PM
gtmccormick
Sep 8, 2013 01:44 AM
dubaholic2
May 24, 2011 12:44 PM
ejxjohnson
Sep 10, 2010 08:21 PM
Scooterewski
Oct 6, 2008 07:00 PM
