1995 4dr idle issues,hard start
Old Mar 16, 2011 | 12:35 PM
bradk's Avatar
bradk is on a distinguished road
Default 1995 4dr idle issues,hard start
What next, when my gas line blew, I replaced it with 250psi high pressure gas line (correct diameter), and return from fuel filter to pump. Recently replaced a leaking tank with new tank and fuel pump(complete). I have 58-60psi, but now the engine cranks for about 6 seconds w/o starting, then fires up with horrible gas smell in exhaust. Then runs great except when idling at a stop, then it seems to get a little too much gas. Every once and a while (2-3 times in last 2 months) it starts instantly like it used to, but this will only happen two or three starts. It always starts instantly after the first cold start. I thought fuel line leak, filter, coil pack, air, but all replaced to no avail. No error codes, no gas smell in the plenum, no obvious issues, also replaced both breather valves in new tank. No vacuum in tank. Only other symptom is when cold start if you dont give it gas, it will rev up a little, in a cycle until it is warm.
Next part I feel like replacing is the driver.
Old Mar 16, 2011 | 06:13 PM
Check fuel pressure and leakdown. Key ON, engine OFF, fuel pump running: pressure must be 55psi to 61psi. Pressure must remain above 50psi for 10 minutes after the fuel pump shuts off. Post your results.
Old Mar 18, 2011 | 01:29 PM
bradk's Avatar
pressures up to 58-60, holds for about 10sec, then I hear a relay, then drops
love-it,.... may his time in office be short.
Old Mar 18, 2011 | 03:20 PM
What does the pressure drop to? Does it remain above 50psi for 10 minutes after the fuel pump shuts off?
Old Mar 18, 2011 | 03:23 PM
bradk's Avatar
i think it drops, ill have to check it out this weekend.
Old Mar 24, 2011 | 12:43 PM
bradk's Avatar
anyone have any experience with flex rubber gas lines? no leaks, wandering if this affects anything
Old May 23, 2011 | 09:34 AM
bradk's Avatar
Default problem solved
fuel leak inside plenum. flex lines into spider. immediate fix and mileage back up to 17.5mpg.
Old May 24, 2011 | 10:12 AM
Thanks for the follow up. That is a very common problem on the CPI engines.
Old Feb 21, 2013 | 06:54 PM
James Nelson's Avatar
James Nelson is on a distinguished road
Default just replaced the whole cpi (spider and lines )
just replaced the cpi and my problem of hard starting is the same
i used one from junkyard and it started but ran rough and the smoke and gas coming out exhaust was the same ...
so i bought one brand new installed and now wont start at all ...idk what to do or where to go from here ...please help
Zach8846
Mar 11, 2014 10:43 AM
Kevin Gore
Dec 13, 2013 09:35 PM
79MKII
Oct 22, 2012 09:40 AM
nitsudredle
May 1, 2012 01:18 PM
B Little
Aug 7, 2011 09:36 AM
