1995 blazer 4.3 vortec Torsion Bar Mount Replacement
Does anyone have a guide or video showing how to replace the torsion bar mounts? I hit a big pot hole and my driver side torsion bar mount bolt on the frame got bent up and now the torsion bar clunks going over bumps
I have just replaced these as part of a Lower Control Arm Bushing replacement. The Torsion Bars need to be unloaded with a special tool then the T-Bolts need to be removed while counting the turns of the ratchet because to reestablish ride height you'll need to be put them back.
It is a high pucker factor job and you must respect the Torsion Bars because if you don't unload them they will push the cross member down with force.
Please be absolutely sure you know what you're doing and what the risks are as I would expect this to be an easy job for a shop.
If I over explained this I apologize but I would rather warn you than leave out something
Brandon Koharchik
01-20-2018 06:38 AM
tony991
06-02-2010 03:57 PM
