1995 wheel bearings
1995 wheel bearings
I am looking to replace my wife's wheel bearings in her 1995 2wd 4door blazer. Should I replace just the bearings or the complete hubs? The abs light is on and these appear to have a built in abs sensor. When I look for hub assemblies they are either for 4wd or AWD.
On my silverado if you use 4wd hubs on a 2wd you'll have problems. Does that apply here? Any and all help is appreciated.
Yes I searched but only thing I can find is just to "use the 4wd tech article"
I am not 100% sure about this but I don't think you can get the bearings separately. The 4WD bearing/hub assembly won't work on a 2WD because there is no axle to hold tension on the bearings. They may bolt in but they will fail very quickly.
I actually found out that the rotor and hub is one assembly which is why I couldn't find it online. Roughly $31 at oriellys. They do NOT Come with bearings though. I will be buying the rotor/hub assembly and new bearings instead of trying to fight the old rusted stuff. I will post part numbers and pictures when I do since there is very little info on 2wd blazers for some reason.
ComputerNerdBD
08-30-2011 10:59 PM
ComputerNerdBD
Tires and Wheels
03-05-2011 05:50 PM
stingray71
08-17-2010 08:24 AM
yzf125
09-17-2005 11:45 PM
BlazerBoy
07-25-2005 11:53 AM
