1996 4x4 problem
Old Mar 1, 2015 | 12:37 PM
txc008's Avatar
txc008 is on a distinguished road
Default 1996 4x4 problem
the other night I put my blazer in 4 wheel drive and everything was fine. Now I can't get it back into 2 wheel drive. It makes a hosling noise until I go over about 30 mph. I tried to put it back in 4 wheel hi and it's doing the same thing. Is there anything I can do to make it go back to 2 wheel until I can get back down to my mechanic
Old Mar 1, 2015 | 12:51 PM
Where is the noise coming from? (front right wheel area, front or rear differential, transfer case etc).
Have you tried to retrieve trouble codes? If so, what are they?
Have you checked all fuses with a test light or volt meter?
Have you checked the 3 vacuum hoses on the transfer case vacuum switch? If they get contaminated with fluid it will cause problems with the axle actuator, (under the battery tray).
sarahj
Mar 3, 2010 12:16 AM
hevi99
Jan 7, 2010 03:45 PM
chuck757co
Mar 18, 2009 03:26 PM
megatrack
Nov 21, 2007 03:53 PM
tpdavis
Aug 10, 2006 03:16 PM
