1996 loosing anti freeze with now visible leaks
Old Sep 27, 2013 | 06:52 PM
craighaz's Avatar
craighaz is on a distinguished road
Default 1996 loosing anti freeze with now visible leaks
My 96 blazer is losing antifreeze and there is no visible leaks. I also have a very rough idle on start up after its been sitting, it then goes away after a minute.my question is. is this an intake leak or head gasket?
Old Sep 27, 2013 | 10:14 PM
Head gasket problems are not common on this engine unless you really cook it! You'd notice other things like serious steam from the tail pipe all the time, radiator hoses getting hard as a rock, constant misfire, etc. Very common on this engine for the lower intake manifold gaskets to leak. Coolant can drip onto an exhaust manifold or crossover pipe and burn off instantly, you'd never see it. Intakes can also leak coolant internally allowing the coolant into the oil. Check for leaks where the intake meets the cylinder head on both sides, and check for coolant in the oil.
Old Sep 28, 2013 | 01:47 AM
Poor Man's Avatar
Poor Man is on a distinguished road
These were well known to have intake gasket leaks. I would bet good money that's your problem. Don't leave it go, you'll end up ruining your engine. I just replaced the one in my sister's 96 a month ago with the same issues, only she continued to drive it and the oil turned to chocolate milk mess. No matter if you do it yourself or have it done, make sure you have the good Fel Pro gasket installed. It will last much longer.
Old Jan 19, 2015 | 08:26 PM
Baddogkuzz's Avatar
Baddogkuzz is on a distinguished road
Thank you for the tips on where to look. Because I'm loosing anti freeze but have yet to find a leak. Now I know where to look.
Old Jan 21, 2015 | 05:38 PM
Gregg64's Avatar
Gregg64 is on a distinguished road
Yeah better check the engine oil. may be leaking internally into the engine and that is bad news for the bearings.
Old Jan 22, 2015 | 05:56 AM
Tajohns34's Avatar
Mine leaked down the back of the engine onto the transmission and I never noticed it.
jamers
Dec 7, 2007 03:32 AM
wythel
Jan 28, 2007 11:53 PM
wilds_dog
Oct 17, 2006 08:20 PM
black19
Sep 10, 2006 01:56 PM
tomsblazer
Dec 21, 2005 08:47 PM
