Anti-Freeze
Old Dec 17, 2005 | 04:48 PM
tomsblazer's Avatar
tomsblazer is an unknown quantity at this point
Default Anti-Freeze
I need to flush and refill my radiator with new coolant/anti-freeze. Is the Prestone stuff actually compatible with the Dex-Cool that may remain in the system? I also did not see the radiator drain plug when looking at the radiator, which side is it on?
I am a former Ford driver and this Chevy thing is taking me a while to catch on.
Thanks for the help!
Old Dec 17, 2005 | 07:15 PM
Default RE: Anti-Freeze
Yes, fully compatible with Dex-Cool. If you are doing a complete flush and fill, you could switch over to the green stuff, its all up to you.
I haven't gone hunting for the drain, but in my experiences, all of my GM vehicles have had them on the drivers side. The newer ones have about a 1" diameter 1/4 turn valve that is almost flush with the side of the tank. It'll open up a passage that will drain out the bottom of the tank.
Good Luck.
Old Dec 17, 2005 | 08:27 PM
tomsblazer's Avatar
Thanks for the info.
I found the drain plug on the passenger side way down at the bottom and under many hoses and fittings[:@]
Old Dec 17, 2005 | 08:35 PM
Ah. Sorry 'bout that. Good to know. I'll be draining my Bravada here next week. I'll flush it out and replace the stat at the same time. I'll be putting back in Prestone.
Old Dec 19, 2005 | 03:48 PM
Hanr3's Avatar
I never use the drain plug, I just pull of my radiator hoses at the thermostate and water pump.
Old Dec 20, 2005 | 02:32 PM
If you do use the drain, remember that on the 96+ (I believe), it is a 1/4 turn valve. If you continue to force it, the valve will come out and, speaking from experience here, it is a real B!tch to get back in! Especially if all you were doing was replacing the t-stat without wanting to drain the entire system! LOL
Old Dec 20, 2005 | 03:55 PM
Hanr3's Avatar
I once took the valve out by mistake. Broke it trying to put it back together. Cheaper and easier to pull the rad hoses.
Old Dec 20, 2005 | 05:10 PM
But Messy'er... LOL
Old Dec 21, 2005 | 08:47 PM
ivannj's Avatar
ivannj is an unknown quantity at this point
There is also two plugs on the crank case to drain the coolant from the engine. One plug on each side of the 4.3 vortec
red4x4
14
Jan 12, 2009 06:05 PM
jamers
Dec 7, 2007 03:32 AM
wythel
Jan 28, 2007 11:53 PM
wilds_dog
Oct 17, 2006 08:20 PM
black19
Sep 10, 2006 01:56 PM
