1996 MAF Sensor reading
Old May 23, 2014 | 05:39 AM
roddy's Avatar
roddy will become famous soon enough
Default 1996 MAF Sensor reading
When engine stopped MAF sensor is reading 0.28 gram / second.
Is this normal?
P0171 & P0174 codes present. 62 lbs fuel pressure holds for 5 min. No manifold leaks, power brake booster or vacuum accessories leaks. Engines runs smooth. No drivability or starting problems.
Old May 23, 2014 | 09:17 AM
burned's Avatar
burned is on a distinguished road
At idle the MAF should be reading close to the size of the engine 4-5 g/s.
How to Clean the GM Mass Air Flow (MAF) Sensor
Old May 23, 2014 | 09:06 PM
roddy's Avatar
Engine warmed up idling @650 rpm MAF reads 4.81
Bank 1 Long Term Fuel Trim @ 650 rpm = 23.67
Bank 2 Long Term Fuel Trim @ 650 rpm = 19.87
Far as I can tell its the original CSFI. Hoping the problem is the MAF reading too much air, causing the ECM to enrich fuel to the limit of the fuel map, triggering the Bank 1 DTC.
chevy lady
Aug 29, 2007 10:17 AM
N1ZZN
May 14, 2006 12:08 PM
khalid_20879
Mar 27, 2006 11:16 AM
MikeForS
Mar 25, 2006 04:43 PM
ivannj
Feb 11, 2006 03:00 PM
