1998 jimmy blend door confusing 6 plug to 4 plug
Old Apr 29, 2022 | 06:45 PM
72Shadetree's Avatar
72Shadetree is on a distinguished road
Default 1998 jimmy blend door confusing 6 plug to 4 plug
1998 jimmy has me so confused I know there is auto and manual blend door actuator my jimmy has manual heat control ordered the proper 4 pin actuator got the old one out it had the broken gear as usual but it’s a 6 pin plug. the correct one I ordered has 4 pin plug. The 6 pin worked great till gear broke so before I install the 4 pin is it gonna work or do I have to get 6 pin confused as how wrong one worked I don’t wanna do this but once lol
Old Apr 30, 2022 | 07:09 PM
Is the plug that connects to the pins on your Blazer have only 4-pins? Was the 4-pin one original or a replacement?
I guess you could always connect it to the plug without installing it to see if it moves back and forth without physically installing it.
Old May 1, 2022 | 04:36 AM
The old one is 6 plug it worked till it broke not sure if it was original or had been replaced before with wrong one. I will check wiring harness plug
JasonW77
30
May 17, 2021 11:23 AM
Jim 1975
Mar 21, 2021 12:12 PM
wild bill
Jul 25, 2014 06:24 PM
bryanhodki
Jan 26, 2014 04:55 PM
jmack15
May 2, 2010 05:45 PM
