1999 blazer 2wd engine in a 4wd???
i have a 1999 blazer, broke a rod in original motor, i pulled it out and scrapped it. i purchased a 2wd motor from the same year. replaced oil pan..... not sure what if anything else there is to change, replace. any info would be greatly appreciated. i know im a noob, but i did my research before i asked..
Oil pans are different, on the 4x4's they relocate the oil filter for a reason. It's a b%@&h to get to. I would swap the remote oil filter system over. Other than that its all the same if you have the same year
ok, i have swapped the remote oil filter assembly, replaced the oil pan, but somethings not right.. i have the front diff dropped down and its like the enigne is just too tall...
if i had the engine bolted down on the mm's again the front diff would not come back up in alignment with its bolt holes
i hope i wasn't lied to about the year of the engine.... is there any way to tell by numbers or marks stamped on it??? EDIT: no i do not have the old motor, if the exh mans are different ill have to buy new ones... :/ i do know that is the same style motor, 4.3l v6 vortec, but its like its too tall, i have thought about taking it from a 4wd to a 2wd but not sure how, also don't really wanna f*ck with the front diff. plus i like 4wd. on a side note i have thought about my styer m95 with German armor piercing rounds(on several occasions)
according to the local chevy parts department, 2wd and 4wd exh mans are the same, also lookie what i done.
