2 RPM while in park?!?!? huh?
Old Apr 29, 2010 | 09:36 AM
ezbiz's Avatar
ezbiz is on a distinguished road
Default 2 RPM while in park?!?!? huh?
I just replaced my 1995 blazer's fuel injector and it was fine. But I noticed that when I put my truck on park the RPM jumps up to 2 and it stays there but if I out the truck into another gear such as drive, the RPM will immediately drop down to 1. I know this is abnormal behavior, can anyone share there thoughts on what is going on with my truck? Thanks.
Old Apr 29, 2010 | 05:52 PM
jjnemoiii's Avatar
jjnemoiii is on a distinguished road
Obviously, you mean 2,000 RPM, and mine (2001) will run at higher RPM also until the engine is warmer or you put it into gear. I believe that this is normal, but could very well be wrong...
Old Apr 29, 2010 | 07:05 PM
Sure sounds like an abnormally high idle to me. The PCM should control idle at somewhere around 650-750 when cold and 550-650 when up to operating temperature. when in gear, it is normal for the idle speed to drop slightly.
As a start, check for vacuum leaks.
Old Apr 30, 2010 | 05:43 PM
88s10Blazer's Avatar
88s10Blazer is an unknown quantity at this point
Mine (2001) will idle at 1.2k until warmed up then runs around 600.
tmoble
Dec 21, 2011 10:58 PM
mtz57
Aug 21, 2010 10:10 PM
mmann32
Feb 26, 2010 04:50 PM
lastcoupe
Street N Strip
23
May 6, 2008 07:39 PM
GrEeNeyedBLAZERbabe
Apr 12, 2007 10:32 AM
