2000 Blazer Engine Angle
Old Apr 17, 2011 | 12:10 PM
kevlar974's Avatar
kevlar974 is on a distinguished road
Default 2000 Blazer Engine Angle
Just dropped the new motor in my blazer new motor mounts and all.
All the bellhousing bolts are torqued and the tranny is fully mounted.
I haven't torqued the motor mount through bolts yet.
I'm not sure but the engine looks like it is leaning to much toward the firewall.
Is this adjustable or do I just tourque it where it sits.
And if its critical what is the proper angle?
Old Apr 17, 2011 | 07:42 PM
Old Skool Soldier's Avatar
Old Skool Soldier is on a distinguished road
The angle of the engine is crucial! The driveline and gear clearences are all based at a certain angle and clearance. If you change the angle,even a couple degrees, you're changing the angle of the driveshaft, putting wear on the U joints and could result in some strange new sounds...
-OSS
Old Apr 17, 2011 | 08:08 PM
kevlar974's Avatar
Well I guess what i am asking is will the engine automaticly have the correct angle if i torque the motor mount through bolts?
I did not remove the tranny during engine removal.
Old Apr 18, 2011 | 06:19 AM
almosta4x4's Avatar
almosta4x4 is on a distinguished road
1st i would check the transmission mount as to make shure its in good condition because if the tail of the trans hangs to low it will pull the engine towards the firewall...
2nd i would use the motor mounts that were on your previous engine as they might be difrent (i had previous problems with using the wrong mounts before )
and also look under your truck and look at both drive shaft angles you should be able to tell wheather they are stressing or not...keeping in mind that if you have a lfit kit install the agle at the yolk will be greater already......
hope this helps other then those few things you could check if the portion of the frame where the motor mounts are bolted to just to make shure nothing is cracked there but this is very unlikly ive only seen this with big blocks and or bored out small blocks.......
and to your question IF you are using proper mounts yes it should have the corect angle automaticly
Old Apr 18, 2011 | 06:26 AM
almosta4x4's Avatar
if the motor mounts are new and the transmission mount is old it could be that the trans mount is holding the transmission an inch or so lower witch was compatible with the old motor mounts seince new ones would have been placed i guess it would be possible that there would be a slight difrence now a new trans mount could fix this...
but 80 % of all mecanic is observation and logic...so its hard to be a real help without seeing lol
Old Apr 19, 2011 | 07:20 PM
kevlar974's Avatar
Tranny mount is new, motor mounts were identical to the old ones, I will check the driveshaft.
I may not have a problem at all the bellhousing top bolts were all just as much of a P.I.T.A. going in as they were coming out, and seem to be in the same location and I still have distributor to firewall clearance.
What got me questioning the angle is the look of the front crank pulley compared to the radiator.
I wasn't really paying attention to this when I took the motor out so it may be right.
I will find out real quick when i get to the fan and fan shroud.
Thanks for all the suggestions guys.
Old Apr 20, 2011 | 08:07 AM
almosta4x4's Avatar
just a stupit guess here check cab mounts unlikely a problem for a 2000 but my 90 s-15 the mounts were shot and the cab..rad suport were crooked .......
Old Jun 6, 2011 | 07:49 PM
kevlar974's Avatar
ended up not being an issue at all once all the bolts were tight it squared up and everything fit fine. thanks again everybody
bill9000
14
Jan 7, 2011 07:54 AM
wlorton
Lifting Tech
Jan 26, 2010 12:28 AM
burningsun
Lifting Tech
Aug 2, 2009 01:14 AM
bobditts
Sep 3, 2008 09:58 PM
AK8BLANK
Suspension Tech
Mar 3, 2007 07:55 PM
