2000 Blazer Rear Rotor Removal
Old May 30, 2009 | 04:21 PM
JHeuler's Avatar
JHeuler is on a distinguished road
Default 2000 Blazer Rear Rotor Removal
How do you remove the rear rotors from this 2000 Blazer?? I have tried a few times with no success at all. I have even used mallets, hammers and wood blocks, etc. What is holding them on. Is the E-brake holding them on?
Thanks
Joe
Old May 30, 2009 | 04:30 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
if you have the e-brake, caliper, and caliper off there should be nothing holding them back. i just got done doing my front rotors a few eeks ago and if took me 2days to get get both rotors off due to the rust. i know in the front there are little retaining type clips so if the rear has these remove those also and grab your BFH and whack away at the rotor thats what i had to resort to and finally the rotors starting coming off inch by inch. you can try spraying some PB blaster where the rotor meets the hub to try and break some of the rust loose.
Old May 31, 2009 | 06:19 PM
JHeuler's Avatar
Default Thanks!
Liquid wrench in between the axle and rotor, a hammer and persistence idi the trick.
Thanks!
Old May 31, 2009 | 07:29 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
The ebrake shoes inside of the rotor can make there own grove in the rotor.
Old May 31, 2009 | 07:37 PM
mech cb's Avatar
mech cb is on a distinguished road
Try backing the e-brakes off manually using the screw valve adjuster thingamajig. Sorry, I can't think of its actual name at the moment.
Old Jun 1, 2009 | 11:55 AM
That would work if there was access to said adjuster. On these trucks though, there is not.
Check out this thread:
Rear Disk Brakes...
Old Jun 1, 2009 | 02:12 PM
mikeinwi's Avatar
^^ nice thread Kyle ill have to keep it handy as ill be tackling the same project within the next few weeks
Old Jun 1, 2009 | 03:30 PM
mech cb's Avatar
Really? On a 2000 blazer? I wouldn't have thought they were that different from the 04. Damn.
vatoDETH
Aug 22, 2010 04:41 PM
Red01AZ
Jun 5, 2010 10:14 AM
louie424
14
Nov 11, 2009 11:26 PM
00Blazer1
Apr 30, 2009 07:05 AM
volrath169
May 13, 2007 09:03 AM
