2000 blazer, running like crap
replaced fuel pump,rotor&distributor cap,plugs, wires, intake gasket, its still hessitating badly, im told they all do it at some point, i just need to get it fixed. any ideas?
Proper fuel diagnosis better then guessing wasting all your money
https://blazerforum.com/forum/tech-a...agnosis-23038/
what brand parts did you use also
crap
ac delco fuel pump, because the GM pump i bought 3 years ago was dying, the plugs etc was all highly recommended as well by numerous professionals and i dont recall at this point the brands
did you check for vacuum leaks?
The spider injection on these is known for causing all kinds of crap when they wear out. Diagnose fuel system first.
going monday to be put on the computer again, thanks for the input, i will post more when i know more and i am taking notes.
My blazer has the timing chain tensioner issue. Fools the knock sensor into forcing the computer to retard timing. I was able to verify this with only a live data stream. You may want to consider this.
Click this: https://blazerforum.com/forum/tech-a...leaning-40420/
It wont hurt to look at the EGR either
Click this: https://blazerforum.com/forum/articl...leaning-40424/
thanks, .....still taking notes, what you and everyone else has described is very accurate
take a business card and cut out a washer to fit between the crank shaft sensor and timing cover to shim the sensor out a little and see if it helps, cured my problem.
