2000 Jimmy dies at every stop!
Before the fuel pump went out this was a symptom,I thought, of a dying fuel pump.The pump did go out and was replaced. Only to have the same problem. It shows no codes, but dies at every stop light, sign, alley intersection. I used a MOC SYSTEMS throttle body and upper engine cleaner thru a manifold vacuum line to clean IAC and EGR. After the smoky clouds still died in the alley when I came to s stop. I'M LOST
the pump was aftermarket. the truck was doing this before the pump went bad. not positive on the tune up, it's probably been a while, it's not my truck.no on the fuel pressure and leakdown check and maf. check that out monday. it's at my cousins shop. he's ase cert. and thought it was IAC or TCC
dbleobarbie
01-09-2014 04:14 PM
dannyb91979
07-16-2013 06:08 PM
bolthandle54
02-05-2012 02:55 PM
live4liftin4848
01-02-2010 10:59 PM
