2000 jimmy,starter engages while running
Old Mar 24, 2013 | 03:24 PM
int3414's Avatar
int3414 is on a distinguished road
Default 2000 jimmy,starter engages while running
the starter engages while its running,ungodly load noise.
does it spurrratically ,STOPS engaging when i pull out the starter relay.
also when i go to start,it just starts without turning key all the way.
thank you for any help.
i will try relay from wife's gmc when she gets home!!~
tried other relay ,not the problem.
could it be the ignition switch
Old Nov 7, 2014 | 05:24 PM
Radio Doc's Avatar
Radio Doc is on a distinguished road
Default Bump to the top
Any solution ?
My 2000 has started doing something similar.
Turn off the key and the starter keeps cranking maybe 1 out of 4 times.
Thanks !!
Old Nov 7, 2014 | 05:33 PM
rxjimmy's Avatar
rxjimmy is on a distinguished road
"it just starts without turning key all the way.
thank you for any help."
and
"Turn off the key and the starter keeps cranking maybe 1 out of 4 times."
My guess, and it only a guess, is the ignition switch has gone bad in both cases.
Old Nov 8, 2014 | 05:12 AM
int3414's Avatar
Default starter engages bye itself
Originally Posted by Radio Doc
Any solution ?
Thanks !!
i changed the wire harness from the ign switch down thru the column to the something under the dash,,i cant remember the part name,but i got all the info plus printed the how to,from this web site...works good no more problems...its a PIA to do but you need the step by step instructions from here,i found the hardest thing was to remove the covers on the steering column.
Old Nov 8, 2014 | 05:17 AM
int3414's Avatar
and
just to let you know,not changing the key,its just the electrical part after that
Old Nov 9, 2014 | 05:35 AM
Radio Doc's Avatar
I was fast enough to catch my starter in the crank-mode, and pulled the starter relay.
I had already pulled the fuse cover and wasn't fast enough on previous tries.
When I pulled the starter relay, the starter was still spinning for several more seconds.
I'm suspecting a sticky starter solenoid and will probably need to replace the starter.
I also have a K5 and that starter replace is a 15 minute job... plenty of room.
Not so with this 2000 4x4 Blazer. Why do they put the bolts where the sun doesn't shine ?
Old Nov 9, 2014 | 10:49 AM
jimspahr@msn.com's Avatar
I hear you. I think they ought to make a GM engineer tear down and replace each device he helps design. If they design a starter, he has to pull it and replace it in his driveway with jack stands and not using a lift. Only then can he 'sign off' on his creations.
Big Phun Dave
Sep 30, 2014 10:22 AM
paco
Apr 4, 2011 11:12 AM
dusted800
Apr 8, 2009 09:20 PM
hawksz28
Apr 18, 2008 01:19 AM
kammino
Nov 27, 2006 11:35 PM
